ac blows hot, gas fine and pump kicks in
Old Jun 24, 2009 | 02:45 PM
jazzypug1's Avatar
Default ac blows hot, gas fine and pump kicks in
i have an 05 grand voyager, the air con blows hot air and wont cool down. i have had the gas checked and it is full and the pump kicks in when turned on any ideas out there.
thanks
Old Jun 24, 2009 | 04:02 PM
pinklesdad's Avatar
gas may be ok but you need to find out if the compressor suction and discharge pressures are different when running if not compressor is not working . this could be caused by compressor fault or a sensor fault. you probubly will have to go to a garage.
Old Jun 24, 2009 | 04:16 PM
Merlin's Avatar
Hi
I second this will need to know the pressures. Is there any hissing noises?
Old Jun 24, 2009 | 04:31 PM
pinklesdad's Avatar
the only way to tell if the pressure is correct is with a gauge or refridgerent top up can with a gauge which has colour band on it to say under ,over or correct charge .instructions on tin. retail around 40 pounds (uk).
Old Jun 24, 2009 | 04:48 PM
jazzypug1's Avatar
thanks for your help will check pressures
Old Jun 24, 2009 | 04:51 PM
Could also be a faulty blend door motor. The blend door diverts incoming air over the heater core or the evaporator core to provide hot or cool air as desired.
Old Jun 26, 2009 | 05:29 PM
cruzenchic134's Avatar
Does it run hot air on all speeds or just high? My van did this and I had to replace the blower resistor. It cost me $36 for a wiring harness from the dealer and $15 for the resistor from O'Reilly's Auto Parts.
Good luck!!!!
Old Jun 27, 2009 | 09:26 PM
jmmillerfzr's Avatar
2004 with a 3.8l it seems to blow cool, but not cold. Seems worse when temps outside are over 90 degrees. The compressor engages for about 15 seconds then off for 30 and this cycle continues. Checked the pressure on the low side and when the compressor is not engaged it reads 70 and when the compressor is engaged it drops to 55. Any ideas if this is correct.
Old Jun 30, 2009 | 05:48 PM
cessna5354's Avatar
Default New Member Asks for Assistance :)
Not to hi jack, but I have the same problems with my '99 T&C. Had the freon checked today, fine, engage the A/C the clutch pulls in and the suction increases, as it should.
I cycled the controls heat-A/C several times and the thud of the damper or blend door sounded like it moved. I now have a little more cooler air, But by no means it is NOT corrected.
My mech said he believed it to be the damper door. BTW I just replaced the steering rack and had the steer column floor cone pushed up in to the underside of the dash. No sure this would have impacted anything.
Where is the Blend Damper, and where / how is it controlled??? I just purchased the Haynes manual, but it appears to be disapointing in this area.
Thanks for all the assistance, I am new to this board and hope to provide as much as I take.
Gary Pasternak
Chipster1903
Aug 31, 2013 10:03 AM
Bobcon
Jul 9, 2011 10:00 PM
jaredfield
Jul 15, 2010 03:25 PM
Chrysler Information
Feb 28, 2008 02:46 PM
fdfever
Sep 27, 2007 01:42 PM
