Airbag p1200 no front left impact sensor communication
As title this is the fault coming up resulting in my airbag light on .
Any one no what I need to do to fix this .. Thanks in advance |
there was a recall for certain years for this (at least in the UK) as water and crud were getting into the connector. Might be worth checking with a dealer if your one needs it.
Failing that it's a case of testing the wiring, cleaning the connectors and as a last resort replacing the sensor Regards Richard |
Hi Chrysler say my vehicle has had the work done for the recall but couldn't tel me when and where .
Could you tel me which sensor it is and where it's located Thanks in advance |
1 Attachment(s)
sensor location attached
so im guessing bumper off .. disconnect battery wait half hour or so to discharge system .
first thing to check is the plugs and wiring if still no joy does anyone no the part numbers of the sensors so i can replace |
no need to get the bumper off if i remember correctly, just the underneath bit
Richard |
Originally Posted by tfb
(Post 92447)
Richard |
for me left is passenger side and right is driver side!, I always take references to left and right as if you are sitting in the drivers seat and NOT facing the front of the car.
Richard |
That's what I thought .. Was just double checking lol
So would this be what I need If not do you no the part number I'll need my reg is yx54vew CHRYSLER GRAND VOYAGER LEFT OR RIGHT AIRBAG IMPACT SENSOR 04671779AC 2004-2007 | eBay |
yep, thats the right part number
Richard |
