Aircon problem 1998 chrysler voyager 3.3 auto.
Old May 16, 2010 | 02:43 PM
bluevanman's Avatar
Question Aircon problem 1998 chrysler voyager 3.3 auto.
hi,hoping someone can help,i have only just got my voyager and i have noticed that when i start up and for the first 10 mins the aircon and the button next to it flash and none of the others work.i have taken the panel off and its looks like one of the pins has burnt out.is this the problem and if i buy a new one will it just burn out again ? also the rear wiper is disconnected and when i reconnect it just does its own thing,are the two faults connected ? very grateful to anyone that can help.
Old May 17, 2010 | 12:31 AM
megamediker's Avatar
Hi blue,
just something brief from Germany. First does it have a 2 zone aircon? (is there a blower switch on the left hand side of the rodio)
okay to find mailfuncts. in aircons there are many possible reasons. A good outhline to find it is Haynes Repair Manual for Chrysler Town & Country. I believe it is 30011. Specially written for 1996 - 2002. Chapter 3.1.
Following the listings in that chapter You should be able to find the mailfunct. Best thing about it is, that it shows the different parts of the system. You will find, that there are quite a few, that have to be taken into consideration, not only the electrical installation. (I doubt if this is it)
Regards Roland
Old May 17, 2010 | 12:46 AM
By the way, have You checked the fuses???
Old May 17, 2010 | 01:42 AM
bluevanman's Avatar
hi,many thanks,yeah i have checked the fuses.the aircon still works if you press the button even when flashing.i already have the haynes manual.the only damage i can find is on the back of the panel and yes it is the two zone type.
Old May 17, 2010 | 07:11 AM
Default how about the old multimeter
Hi Blue,
well Multimeter is how we call it over here. If it is burnt, is the connector still working? (line through, resistance) Would a new connector, or even pannel help. I have seen various in ebay, why not try it, they aren't that expensive.
Regards Roland
Old May 17, 2010 | 07:17 AM
If the connector seem to be burnt, there must be a reason for it and You need to find that out, before You go on. Did You check on the cabeling? Maybe parts of the cabeling is brocken, or the isolation was rubbed of at some place. Them things are hard to find.
Did someone check the preasure of the system.
actd
11
Nov 3, 2021 03:41 PM
AlanC
Aug 14, 2014 02:08 PM
rodger
Jun 23, 2014 01:35 PM
nitro_warrior
Feb 24, 2014 11:29 AM
dandiesel
Feb 2, 2007 08:24 PM
