another issue sliding door...
hi everyone , Merry Christmas and happy new Chrysler year!!!
My voyager 2.5 crd 2002 have a small issue, the slide door doesnīt open with remote ou button FOR THE FIRST TIME OF DAY just open a little inches after this, i open all manually, close manually and after i use a remote control or buttons and its working normal, after some hours ( one nigth or 12 hours) the problem start again, i open and close manually and after... its working... tomorrow i will upload a movie the show what's happens. NOTE: ALL DOORS ARE LUBRICATED WD40 OR SIMILAR NOTE 2 just the right door have a issue, and this door is more ""heavy"" please help :) |
Originally Posted by tsainhas
(Post 44224)
please help :) Seconly, Pop a link off of the wiring track at the sliding door, and firmly tug on all the wires...ensure none are frayed or rotted. (The solid Black in particular). Also try to note if the interior lamps work properly while operating the sliding door..this will often give you a clue as to electrical or mechanical. |
Video of my problem
http://www.youtube.com/watch?v=BOJr-36fLAM
i think the door canīt closed totally, but the interior lights stay on when i use the remote control to open, and when close the lights turn off, the central work is normal, and the door work normal, its possible any adjustment?:confused::confused::confused::confused : thanks |
:):) Look carefully at the wiring track for the door......Pop a link apart, and pull on each individual wire, to ensure there are no "Breaks" or worn spots.....(The Thick Black wire is a common trouble spot) My gut tells me you need a LATCH.... |
Originally Posted by Djinn-n-Tonic
(Post 44245)
Look carefully at the wiring track for the door......Pop a link apart, and pull on each individual wire, to ensure there are no "Breaks" or worn spots.....(The Thick Black wire is a common trouble spot) My gut tells me you need a LATCH.... thanks for your attention good bye :) |
door....
(Post 44245)
If I recall, There are 2 phillips screws on the trim piesce on each side of the glass, and one or two that will be exposed once the trim is removed. The rest are "PUSH PINS".......
Just a hint.....Get into the second row seat, and close the door approx 3/4 odf the way, and work from inside..... Quick try.....Get some solvent, (Brake Kleen, Carb cleaner..etc....NOTHING OIL BASED) and see if youcan spray some of the crud out of the latch . it "MAY" help, it may not, but before ripping the panel off, its worth a try. |
Sliding Door Issue
Hi there,
Did you get this issue resolved as i have watched your vidoe and have the same problems with both doors, So if you have fixed it i would like to know how Regards Chris |
Chris,...
Follow thru the thread and make the checks I told the OP to do......The doors arent as complicated as they seem. |
slinding door
Originally Posted by chris.parham
(Post 44782)
Hi there,
Did you get this issue resolved as i have watched your vidoe and have the same problems with both doors, So if you have fixed it i would like to know how Regards Chris Hello, not yet, because i didn't do anything ( no TIME)... but i want resolve, maybe before Mars, i promise when the problem as resolve i tell you and post in forum! Tanks Tiago |
