Blinking dash lights
Old Sep 5, 2012 | 06:50 PM
jvh24521's Avatar
Default Blinking dash lights
Hi folks,
99 Grand Caravan
Starts and runs normally. After about 30 seconds the dash and overhead computer lights flash at a steady rate, about twice per second. If I turn on the park lights or headlights the dash dims normally.
What's it trying to tell me?
Thanks,
jvh
Old Sep 5, 2012 | 08:24 PM
jvh24521's Avatar
When I got home it was getting dark and now I see the headlights are blinking too.
Old Sep 7, 2012 | 11:04 PM
Raptor 07's Avatar
Make sure battery post connections are clean and tight. Have the battery load tested. Check battery cable ground connections and battery power connection at PDC for looseness or corrosion. Test alternator output at battery connections using a voltmeter. Should see a steady 13.5 to 14.5 volts with engine running.
Old Sep 8, 2012 | 11:45 AM
jvh24521's Avatar
Thanks.
Battery is quite new but it did pull down pretty hard when I tried to start the other day. Battery post needed cleaning for sure. Didn't have tools for that while at work so I pulled some fuses like engine and EBT or some such, basically all TLA's I didn't recognize and it cleared. Got back home (from out of town work) this weekend and cleaned the posts.
I hear different ideas about what to put on terminals from silicon paste to WD 40. I haven't done this battery yet but I have good luck gluing a penny halfway between the post. Got the idea from the zinc sacrificial anodes on my boat's lower unit.
thanks,
jvh
Old Sep 8, 2012 | 12:59 PM
Raptor 07's Avatar
Congrats. Any old grease works for me.
Old Sep 10, 2012 | 08:39 PM
jvh24521's Avatar
Meant to ask earlier. Are the blinking lights an intended indication of some sort or just an abnormal state. Can't imagine why lights would blink unless part of the anti-theft algorithms are activated.
thanks again,
jvh
debbieking
Nov 20, 2018 08:15 PM
GO PATS
Dec 11, 2012 08:53 PM
ecarter
Sep 14, 2012 11:15 AM
lorimissjane64
Dec 30, 2011 03:47 PM
debcoutcher
Mar 12, 2011 09:37 PM
