Blower Motor Failure
Old Jul 10, 2008 | 11:52 PM
kc9dre's Avatar
Default Blower Motor Failure
Ok, being the electronics tech that I am, I began troubles shooting this problem. I have an 03 T&C Limited w/3 zone autocooling. I popped down the glove box and started checking connections, so lookin at the power module resistor, I took off the connector on the left (3 wire) and chacked got voltage, there is voltage going in, so I checked going out and it is good. Now coming out of the mod there is voltage there, but motor dosen't turn. So I bought a new motor.. and nothing.. But I was told that if the mod went out the fan would run on high by the dealer.. ideas?
Old Jul 11, 2008 | 07:55 AM
lugnuts1967's Avatar
Default RE: Blower Motor Failure
I still put my $$ on power module. When mine failed it stopped the fan alltogether. It is a 5-min fix and $70-$80 for the part (you could do it in the parking lot in no time - just take your 1/4"ratchet, extension and socket and empty your glove box before going). The replacement was different on the sensor side as well as missing one terminal connection. The dealer said that it was redesigned for efficency and the terminal was a redundant connection. Regardless, it worked.
Old Jul 11, 2008 | 10:26 PM
JeepAndAVan's Avatar
I agree with lugnuts, when it fails, it can be locked on high or not running at all. Mine died two weeks ago and it stuck on high but the parts guy said it happens both ways.
good luck,
-Jerry
elpaso
Cirrus & Breeze
Aug 8, 2011 05:30 PM
Vanman
15
Jul 17, 2009 06:17 PM
bmfay
Apr 9, 2007 08:37 PM
bmfay
Apr 2, 2007 09:49 PM
94 Octane
Nov 10, 2005 11:39 AM
