Cam Belt + Water Pump
Old Jul 19, 2014 | 08:10 PM
  #21
TimmyTim's Avatar
Thumbs up
Originally Posted by rodger
Hi Alan
I did my own belt change see link below.
https://www.chryslerforum.com/forum/...-change-20832/
I think what might have happened is they were going to do the belt change without using the locking pins (crankshaft/camshafts) and you can do it this way. If I remember correctly to get the waterpump off you have to remove the timing chest backplate, which means you have to remove the camshaft pulleys (they are a taper fit not keyed to the shaft) and that means you then have to use the locking pins or you lose the camshaft timing.
So in short, they were going to do it the quick way and then discovered they couldn't and that they needed the timing pins.
Hope this helps.
Rodger
Where abouts are you Rodger?
Old Jul 20, 2014 | 06:59 AM
  #22
rodger's Avatar
About 8 miles south of Maidstone, Kent.
Old Jul 20, 2014 | 08:01 AM
  #23
TimmyTim's Avatar
Wish you were closed to cardiff mate
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
gbeach
Sep 13, 2010 12:09 PM
montreal
May 7, 2008 10:59 PM
sebringphanatic
Mar 22, 2008 07:57 AM
