Can I get replacement key fob in U.K for Grand Voyager
2001 model and doesn't have a key fob. Is there anyone you know who can sell/supply me a replacement key fob
can I buy one one on ebay and have it coded to car? Thanks |
Read these threads in general first, this one in the particular, then come back with questions. The short answer is if you have an existing coded keyFOB already you can self-flash another, if you don't have at least one its main stealer and a lot of money.
Best bet is to buy one on eBay and take it to the dealer for coding. It'll save some money vs. paying full sucker price at the dealership. They'll still charge you for the programming. Once you have one, buy another on eBay and program it yourself. When doing so, be aware that you must program both fobs in rapid succession to have them work.
(Post 80745)
Ive contacted that company before about my voyager key fob and they told me they cant do Chrysler
Pete....... |
So how about the actual key/blade itself. Can it be cut by locksmith?
yes but you have to find one that does Chrysler keys one company i know who does is Timpsons but they are not cheap i believe they also do key fobs i phoned them once and they wanted £150 for the fob alone and that was programmed as well ive never used them but are worth a try also its easier to get a ign key cut and programmed than it is for a remote key fob but search the internet with your local area im sure you will find someone...
Also you can get them on eBay just go to your local dealer give them your reg number or vin number and they will give you the correct key fob part number and they will give you the price of a new one then type that number into ebay and see what comes up i have this same problem with my voyager as it goes but for some reason its not accepting a key fob even the right one so there,s some fault somewhere in mine i hope you have more luck with yours That's my voyager pictured at the side of all my messages i just put it up today as it goes :) Pete........ |
