chrysler voyager 2.5 td
Help!!!!
my voyager has lost power. its been ok till now, apart from general wear n tear stuff but today it held back, wont go over 50 mph and when i reach that speed it pulls me back please help many thanks karen n pete |
RE: chrysler voyager 2.5 td
could be a fuel blockage maybe fuel filter ,worth a try also clean air filter . water in diesel .does it start ok in morning?
does it rev freely when standing still ? bad smoke from exhaust ? what colour is it ? |
ORIGINAL: muso58 could be a fuel blockage maybe fuel filter ,worth a try also clean air filter . water in diesel .does it start ok in morning? does it rev freely when standing still ? bad smoke from exhaust ? what colour is it ? i have bled the fuel system,its just has full service 2 weeks ago,it starts fine ,revs fine,and got white smoke when first started,(about 5 seconds) then clears. i must add it now STINKS of diesel when i drive it,( coming in though vents)and under the bonnet. i have today noted a leak underneath the front and its diesel only a very slight leak.1 drip every 1/2 hour or so ( yes i did lay under it waiting!!!!) any suggestions as to where this is coming from? thanks again karen n pete |
white smoke combined with diesel smell could be excess
fuel problem has fuel consumption gone up ? if so could be inj pump problem(which could explain fuel leak ,maybe a seal gone in pump ) or maybe worn injectors . white smoke can also mean head gasket problem , take off lid of header tank when cold on fast tickover see if you have any bubbles in water and/or combustion gas smells . |
i have the same problems whits my 2.5 td losing power and make smoke at 2000 rpm
i found that the intercooler was laging in the top i change it and its work perfeckt now |
