chrysler voyager 2.5 td
Old May 29, 2006 | 05:07 PM
peteats's Avatar
Default chrysler voyager 2.5 td
Help!!!!
my voyager has lost power.
its been ok till now, apart from general wear n tear stuff
but today it held back, wont go over 50 mph and when i reach that speed it pulls me back
please help
many thanks
karen n pete
Old May 31, 2006 | 05:31 AM
muso58's Avatar
Default RE: chrysler voyager 2.5 td
could be a fuel blockage maybe fuel filter ,worth a try also clean air filter . water in diesel .does it start ok in morning?
does it rev freely when standing still ? bad smoke from exhaust ? what colour is it ?
Old May 31, 2006 | 01:59 PM
peteats's Avatar
ORIGINAL: muso58
many thanks for response,
i have bled the fuel system,its just has full service 2 weeks ago,it starts fine ,revs fine,and got white smoke when first started,(about 5 seconds) then clears.
i must add it now STINKS of diesel when i drive it,( coming in though vents)and under the bonnet. i have today noted a leak underneath the front and its diesel
only a very slight leak.1 drip every 1/2 hour or so ( yes i did lay under it waiting!!!!)
any suggestions as to where this is coming from?
thanks again
karen n pete
Old May 31, 2006 | 02:36 PM
muso58's Avatar
white smoke combined with diesel smell could be excess
fuel problem
has fuel consumption gone up ? if so could be inj pump problem(which could explain fuel leak ,maybe a seal gone in pump ) or maybe worn
injectors .
white smoke can also mean head gasket problem , take off lid of
header tank when cold on fast tickover see if you have any
bubbles in water and/or combustion gas smells .
Old Oct 11, 2007 | 02:40 AM
saaby's Avatar
i have the same problems whits my 2.5 td losing power and make smoke at 2000 rpm
i found that the intercooler was laging in the top i change it and its work perfeckt now
alexnz
Mar 17, 2015 03:06 AM
