RoseParr |
04-25-2022 10:26 AM |
This problem may be hiding in damaged areas of the hard disk, because of which you can't copy anything there, although there is enough space on the hard disk. I had a similar situation when I was transferring all the data from the old computer to the new one and I was unable to transfer some of the data due to a disk error. The disk wrote to me that there was not enough space, although there was enough space, I did not know what to do and tried to fix the errors on the disk through the console and I succeeded. However, I took the disk for diagnostics later to http://salvagedata.com and the guys confirmed that everything is fine with it and it is serviceable. I do not know if you will be able to repair your hard drive in the way that I used, if not, then I advise you to take it to master. Good luck!
