Copying a CD onto HDD.
Old Jul 2, 2016 | 03:40 PM
jkbeals64@aol.com's Avatar
Default Copying a CD onto HDD.
I have a 2008 T&C and have copied CDs onto the HDD before but now they won't show up. It copies no problem and won't copy again because it says it is already there. HDD is about half full. Anyone experienced same thing? Any ideas?
Old Apr 23, 2022 | 01:07 PM
ZoeSkinner's Avatar
Maybe there is a problem in the HDD. I had a similar problem and after cleaning up the HDD, everything started to work normally
Old Apr 23, 2022 | 01:08 PM
RoseParr's Avatar
It is an old thread. I don't think this person needs your help anymore
Old Apr 24, 2022 | 03:16 AM
What's a CD?
Old Apr 25, 2022 | 10:26 AM
RoseParr's Avatar
This problem may be hiding in damaged areas of the hard disk, because of which you can't copy anything there, although there is enough space on the hard disk. I had a similar situation when I was transferring all the data from the old computer to the new one and I was unable to transfer some of the data due to a disk error. The disk wrote to me that there was not enough space, although there was enough space, I did not know what to do and tried to fix the errors on the disk through the console and I succeeded. However, I took the disk for diagnostics later to http://salvagedata.com and the guys confirmed that everything is fine with it and it is serviceable. I do not know if you will be able to repair your hard drive in the way that I used, if not, then I advise you to take it to master. Good luck!
Mr300c
Oct 28, 2018 10:37 AM
lzollner
May 23, 2010 08:17 PM
duffer
Jul 8, 2009 05:54 AM
dodguy
May 7, 2008 08:19 PM
blindmutt
Mar 14, 2008 08:54 PM
