Cruise control doesn't work
I have a 2002 Chrysler Voyager and the cruise control quit working. I can't find a fuse for it. Does anyone know how to fix this?
is the light on? or does it come on then go off? or stay on but not work. if it's the latter I would be looking for and air leak as it is vacuum control if it's a petrol. Need more info to help more but there is no fuse.
light doesn't come on ever. It doesn't work at all_ like it been disconnected.
petrol or diesel?
petrol
It is a petrol.
i have the same problem cant figure out what it is. changed the clockspring and that dident fix it
Not sure if this is your issue or not, but the only time I have had my cruise control quit working for what seemed like no reason in past vehicles was when the alternator was beginning to go.
Dumb one I know, but do check the plug that connects to the vacuum. This was simply hanging out when I bought my '04 GV recently and re-connecting sorted it. Alternatively, look for a leak in the piping and check the CC unit's own "parallel" throttle cable is connected and not jammed.
Good luck |
2012 Town and Country cruise symbol not on/working
What I did is disconnect the battery for 5 minutes. ( Then turned ignition switch on/off) with no battery) then I reconnected the battery. Right now my cruise works.
(Not sure for how long it will keep working) I'm not a mechanic and this may seem silly , I just used my own crazy logic. ... But it works . |
