Cruise control doesn't work
Old May 17, 2010 | 10:49 AM
thebursbys's Avatar
Default Cruise control doesn't work
I have a 2002 Chrysler Voyager and the cruise control quit working. I can't find a fuse for it. Does anyone know how to fix this?
Old May 17, 2010 | 06:15 PM
Merlin's Avatar
is the light on? or does it come on then go off? or stay on but not work. if it's the latter I would be looking for and air leak as it is vacuum control if it's a petrol. Need more info to help more but there is no fuse.
Old May 18, 2010 | 05:30 AM
thebursbys's Avatar
light doesn't come on ever. It doesn't work at all_ like it been disconnected.
Old May 18, 2010 | 01:17 PM
Merlin's Avatar
petrol or diesel?
Old May 26, 2010 | 10:04 AM
thebursbys's Avatar
Default petrol
It is a petrol.
Old Jun 2, 2011 | 03:28 AM
mathewsman's Avatar
i have the same problem cant figure out what it is. changed the clockspring and that dident fix it
Old Jun 2, 2011 | 04:55 AM
andyr78's Avatar
Not sure if this is your issue or not, but the only time I have had my cruise control quit working for what seemed like no reason in past vehicles was when the alternator was beginning to go.
Old Jun 5, 2011 | 06:29 PM
GrahamLemon's Avatar
Dumb one I know, but do check the plug that connects to the vacuum. This was simply hanging out when I bought my '04 GV recently and re-connecting sorted it. Alternatively, look for a leak in the piping and check the CC unit's own "parallel" throttle cable is connected and not jammed.
Good luck
Old Jul 3, 2017 | 04:35 PM
Dan Rossi's Avatar
Default 2012 Town and Country cruise symbol not on/working
What I did is disconnect the battery for 5 minutes. ( Then turned ignition switch on/off) with no battery) then I reconnected the battery. Right now my cruise works.
(Not sure for how long it will keep working) I'm not a mechanic and this may seem silly , I just used my own crazy logic. ... But it works .
drolds
19
Jan 10, 2022 08:45 PM
pete@co.uk
Apr 12, 2010 05:34 PM
CharlieC
Jun 28, 2008 06:41 PM
70TorinoGt
May 1, 2008 10:50 AM
DJ SHORTY
Mar 7, 2008 08:19 AM
