Dash light Town & Country -99
Old Mar 14, 2007 | 07:25 PM
anteman's Avatar
Default Dash light Town & Country -99
Hello
I have this problem the dash light is "dead". It started to go on and off but now it's always off. Everything elseworks fine speedmeter and so on. Pleas help me so I dont have too use a torchto see my speed.
Regards, Anteman
Old Mar 14, 2007 | 09:02 PM
Default RE: Dash light Town & Country -99
does any of the other lights work aka the radio the ac control head the over head the same lights that light up as u drive at night?
Old Mar 16, 2007 | 03:29 PM
anteman's Avatar
it's only the lamps for driver info that are dead. eg. the ones behind the stearingwheel.
must thank you for the fast replay CRYSLER TECH i hope you have a cheap solution on my problem...
Old Mar 16, 2007 | 11:05 PM
well got 2 ideas First the more expensive route replace the printed ckt board and have some one program the guages when done or there are posts on here for a solder fix bight be for your issue not sure but seen it on here. If it was one bulb I would say replace the bulbs or all of them but if they all went out at the same time na board issue
Old Apr 1, 2007 | 12:11 PM
anteman's Avatar
how do i dismount the dashboard?
Old Apr 1, 2007 | 02:20 PM
anteman's Avatar
I don't think it i's a solding problem. The pins on the red socket have contact with the lamps (the + pin is a little bit burned). So I presume there is no power to the red socket. Can someone give me a hint how to procede the problemsolving?
Old Apr 1, 2007 | 03:37 PM
replace the ckt board and have a dealer or some one with a good enough computer to reprogram the insterment cluster
Old Apr 1, 2007 | 08:39 PM
anteman's Avatar
okay. but one thing bothers me. no 12Vone the pins in the redsocket, power to the 194 lamps("big ones"). it i's only teh 194 lamps that dont work. everything else works just fine. and one thing more there is no power on fuse #1 and 3 the one for the gauge lamps??
Old Apr 2, 2007 | 03:35 AM
check all the fuses then and get back to me
Old Apr 12, 2007 | 08:16 AM
anteman's Avatar
all fuses are ok.
