ECU connector pins id-
Old Oct 8, 2012 | 05:01 PM
nelpasa's Avatar
Default ECU connector pins id-
2002 TC 3.3L no EGR, no flex : need the ECU connectors pins ID. Need the the wire to injector #5 specifically.
Getting constant( not intermittent) .24mv at the both sides of the connector to the main wiring harness , using digital meter to measure voltage
Old Oct 9, 2012 | 12:50 AM
Raptor 07's Avatar
PCM connector C1 contact #15 brown/orange tracer to pin #2 at injector #5
Old Oct 9, 2012 | 07:06 AM
nelpasa's Avatar
Thanks a lot.
Do you have the connector pin layout? Is that the top connector to the ECU?Which is the location of number 1 pin in the conn.?
Old Oct 9, 2012 | 01:11 PM
Raptor 07's Avatar
Wish I could tell you but I was just looking at a wire diagram. That info isn't given. A pretty good bet pin #1 is at upper left but then we are talking about Chrysler so logic may not apply. All the injector wires are on consecutive contacts in the same C1 connector. Send me a private message with an email address and I'll send you the wire diagrams.You can then match up the wire color IDs and identify the connector and pinpoint #5 that way. Kinda through the back door.
Old Oct 9, 2012 | 04:09 PM
nelpasa's Avatar
thanks alot. I just finished removing the cover of the wiring harness, looking for a short. I did not find one, so I think I have an ECU problem.....sh.....
this Chrysler are sh...
lutefisk69
Apr 10, 2012 07:57 AM
3.3lxbluevan
May 2, 2009 06:34 PM
Spiderman
Mar 3, 2009 07:34 AM
GLC
Oct 5, 2007 01:11 PM
Feb 22, 2006 07:55 AM
