EGR block or not
Old Oct 9, 2017 | 05:06 AM
dieselvoyager's Avatar
I don't got exprince with block egr but a friend of me owns a CASE tractor dealer ship and he said if the engine is run high load moste of the time don't block egr course it lower the combustion temp so if block it could course at melt down the piston. So if you don't got a towhook it's proberly not a problem .
Why not just use diesel aditive every 10000km or together with oil change. I do and never had problems CRD2.5 with over 500000km on the clock.
Old Oct 9, 2017 | 12:05 PM
Originally Posted by andyb2000
Blocking the lower pipe with an old 1d penny is a tried and tested solution, and easy to try out (and remove if needed) so I'm going to give that a go.
Are you going to drill a hole in the penny Andy? If you don't then I think you can expect to see the engine warning permanently on. Either way, I'll be interested to hear the results.
Old Oct 9, 2017 | 02:44 PM
I've noticed that pipe on Alan's picture going into the bottom of the intake manifold and traced it around the back to the Elusive EGR. Many times I've read on here about blanking off at EGR itself. Always wondered if there was a reason like a blanking problem here done by a simple penny..
jimG
Sep 8, 2010 12:26 PM
psalvitti
Aug 28, 2008 12:55 PM
gjisin
Dec 27, 2006 07:57 PM
Rangerdude
Jul 23, 2006 10:03 PM
globalgrooves
Jun 18, 2006 01:38 AM
