Engine Coolant...Help Please
Old Feb 15, 2010 | 08:15 AM
masterfulmatt's Avatar
Default Engine Coolant...Help Please
Hi
I have just bought a 99 3.3 Grand Voyager, ,under the bonnet (hood) I'm in the UK to the left hand side is an expansion tank, labelled on the cap "Caution Engine Coolant Only see owners manual"
As there is a seperate cap for the radiator, what goes in here...Water / Anti Freeze mix?
As you can guess I don't have the Manual!
Matt
Old Feb 15, 2010 | 01:34 PM
I wonder's Avatar
engine coolant means exactly that.
expansion tank you should fill up with the same kind of fluid that's cooling your engine. it should be a mixture of antifreeze and water, hopefully of the same kind (same colour as the fluid already in).
keep your eye on the fluid level.
if it's goingdown, you have a leak somewhere.
Old Feb 18, 2010 | 12:49 PM
Thank you as i thought!
TimmyTim
Oct 17, 2013 03:30 PM
donnyohs
Nov 14, 2011 11:57 AM
GCookie
9
Jul 15, 2011 02:24 PM
Daryl Baines
Mar 17, 2008 07:36 PM
donnyohs
Oct 2, 2007 11:26 PM
