Engine cooling fan motor replace
Old Apr 1, 2010 | 01:58 PM
davet's Avatar
Default Engine cooling fan motor replace
2000 T&C Limited, 3.8. 2 electric fans on radiator all within one shroud assembly. One fan is on driver's side while the other is in the center of the van. That center motor is rough and needs to be replaced. Can I replace just the motor pretty easily? It lists for $55.00. How does the fan come off the old motor and can it be used again on the new motor? Entire assembly with both motors and fans is $85.00. Does the radiator need to be drained and pulled for clearance? Looking for easiest/cheapest route. Thanks.
Old Apr 1, 2010 | 10:12 PM
replace both fans with the assembly 4 bolts and its out
Old Apr 1, 2010 | 11:35 PM
davet's Avatar
Thanks. CHRYSLER TECH, could you check out my latest post titled "Disconnect steering column shaft from rack" please.
cris1966
Aug 26, 2014 09:59 AM
rojo
Mar 22, 2009 09:25 AM
defektivrobot
Apr 22, 2008 12:47 PM
dandiesel
Feb 2, 2007 08:24 PM
Ironside
Jun 10, 2006 01:42 PM
