Which Engine Oil 2.5 CRD 109k?
Old Jan 7, 2015 | 02:18 PM
Daniel Williamson's Avatar
The 5w30 oil I have been using is semi synthetic from Castrol, the manual says it recommends 10w40 or 5w30 is ok if temps fall below -10. The only reason I got 5w30 in the first place was because I didn't have the manual at the time and was in Halfords and they suggested this :/ now I am starting to think I need to do a complete oil change, last thing I want is to cause something to go wrong in an old engine if the weight is wrong
Old Jan 7, 2015 | 02:52 PM
Old Jan 7, 2015 | 05:14 PM
Vmaxxer's Avatar
I would recommend 5W30 full synthetic or 10W40 full synth wil work too as long as you are not living close to the north pole. but I would definitely NOT go for the cheapest oil brands possible.
The difference between a good long lasting oil and a soon depleted, less performing oil is in the additives (the dopes)
A-brand oil companies put a LOT research and effort into the additives in their oils to beat the competition and that makes their products more expensive.
In almost any case A-brands are worth the bucks in my book.
Old Jan 7, 2015 | 05:26 PM
Thanks vmaxxer, I shall keep it in then until I do its next oil and filter change in the spring, I thought comma would have been a good idea as I already get the anti-freeze and ATF+4 fluid from them but I see your point that companies such as Shell, Castrol would of course research more into additives to aid the engine parts etc
one question I have is what oil filter do you use? when I search for them online there seems to be many different varieties.
Only had my GV 7 months so not done a change on it yet
Old Jan 7, 2015 | 07:10 PM
  #15
Vmaxxer's Avatar
I have never heard of Comma, could be not too bad though, but personally I stick to Shell. lately I did some price research and Valvoline came out pretty good in price<>quality comparison
I use Mann filters, because I am used to that brand in my other car (Mercedes)
Old Jan 8, 2015 | 03:36 AM
  #16
Thanks, I am going with the shell Helix Diesel HX7 I shall try the Mann filters out also.
Old Jan 8, 2015 | 12:15 PM
  #17
chrysler1's Avatar
What ever grade of you use, I would definitely use fully synthetic. As mentioned the turbo bearings get very hot.
Dagny
Mar 23, 2011 01:17 PM
rodger
Oct 6, 2010 04:59 PM
Hank1946
Jun 26, 2009 10:00 PM
Jun 25, 2005 06:08 PM
jamoleh
Mar 25, 2005 06:38 PM
