Engine swap question
Old Jul 19, 2016 | 10:00 PM
Towncountry's Avatar
Default Engine swap question
I need to replace the engine on 2006 Town & Country, 3,8. Is there a way to know what the donor vehicle should be- does it for example have to be exact same year to fit ? Can it be from Dodge Caravan ? Or can I know it by the VIN number ?
Old Jul 19, 2016 | 11:07 PM
2002 on up should work just might need to keep same harness and some sensors
Old Jul 20, 2016 | 01:49 PM
Yes gone are the good old days of buying electrical parts and just fitting them. Now you've got to ask the vehicles permission to fit them by knocking at the door of the ECU. So we are now into interrogating the ECU via a plugin, if you have the equipment that is. Some electronic parts learn by themselves though. So the worse scenario is changing electronic parts and it refusing to start.
Old Jul 22, 2016 | 06:26 AM
Vonhofinvule's Avatar
Hi, you can search for an engine from the T&C or Caravan etc as they are all the same, however, stick to years 2001 through 2007. 2008 and later had slight modifications made which dropped both BHP and Torque however combined with the new 6sp transmission improved overall performance and economy so I'd stay clear of these because you may run into engine management compatibility issues.
lesteryeong
Jun 19, 2015 04:35 PM
Scotsman4th
Sep 25, 2014 02:52 PM
lep0407
Jun 6, 2013 02:22 PM
andbudzi
Feb 20, 2008 04:07 PM
andre2000
Oct 5, 2006 08:52 PM
