error code p0420 and whining
Old Jul 20, 2011 | 09:06 AM
bradleigh1977's Avatar
Default error code p0420 and whining
When i got my 3.3 2003 limited xs it has a whining, which got higher the faster then engine revved--but it didn't really bother me--but got the engine management light on today--and got the code p0420--
now done some searching and its to do with emmision or fumes or cat etc...now i have also found this.....
Had the same problem took forever to find where the whinning was coming from. Look under the middle of the car while running and listen for a whine while someone else eccelrates it. There is a plastic 3 ball looking thing that has a vacumm in it that helps with pressure. Mine was shrunken from heat and therefore leaked its called a Vac Harness and it was 8.00 from the dealer. part # was 4431325 hope this helps good luck.
Im no expert but they could be linked? any one else have any ideas?
Old Jul 20, 2011 | 09:31 AM
I have just been reading the chrysler forum for p0420 codes....now my car has covered 180000 miles, but the car is runnig fine, except the engine managemnet light, and the p0420 code. Is hard to change the 02 sensors, should i start here?
If its the sensor for the cat, where is this on my car? - as the "heat sheild" on the top of my manifold where it meets the engine has all burnt/rusted off...is the cat sensor in there or further along the pipe---if its no where near i'm sorry!!
Old Jul 20, 2011 | 11:09 AM
do u even know what the code 420 is? if not go look it up an evap harness or an o2 sensor wont do anything
Old Jul 20, 2011 | 11:57 AM
I'm just going on what i have read on the internet. What would you suggest then?
Old Jul 20, 2011 | 02:50 PM
this is one of those things when u read what the code says u will know what will be needed to fix the car.
Old Jul 21, 2011 | 02:06 AM
ok thankyou, i only got the 420 code. thanks for that. i'll get the code read properly.
thanks again
Also--i was going to get someone round before i read the code, but then thought i didn't need him. He's code machine will not only get the 420 code it will also be able to tell me what is the "actual" problem...is this correct?
Old Jul 21, 2011 | 02:56 PM
P0420-1/1 catalytic converter efficiency
cstlou
Dec 10, 2015 04:23 AM
green earth
Feb 23, 2012 02:00 AM
SpudlerT+CTouring
Sep 15, 2011 05:11 PM
gulfstream
Jul 4, 2011 11:01 AM
robertearl
Feb 12, 2008 09:47 PM
