Error Codes & Turn Off Check Engine
Old Apr 6, 2008 | 02:33 PM
VanJockey's Avatar
Default Error Codes & Turn Off Check Engine
Can anyone offer advice on how to see the computer's error codes? My check engine light is on. I know what caused the issue, but I'd like to see the codes in the computer andand I'd like to reset it to turn the check engine light off. I'd appreciate any help or advice.
Old Apr 7, 2008 | 08:04 AM
jdl's Avatar
jdl
Default RE: Error Codes & Turn Off Check Engine
If this is a 2001 model, you may have to use an OBD 11 code reader or scanner. Some of the national brand autostores will check codes for free
On some Chrysler OBD11 models, you can get some codes by cycling the ignition switch, not sure that will work on your vehicle.
Old Apr 7, 2008 | 09:24 AM
I wonder's Avatar
well, it's not OBD 11 but OBD II (two).
check engine light can be turned off, but on some cars fault stays memorised in the computer.
everything you need to know is here
http://www.allpar.com/fix/codes.html
Old Apr 7, 2008 | 08:58 PM
VanJockey's Avatar
Thanks for your response. This is very helpful.
Jfizzle
Feb 22, 2020 04:37 PM
Floyd Newport
14
Dec 9, 2010 09:30 PM
e49735
Apr 25, 2008 03:19 PM
contourfreak22
Feb 14, 2008 07:39 PM
webbphoto
Jun 19, 2007 09:22 AM
