EVIC compass: busted, or I am too dumb to figure it out?
Old Mar 28, 2013 | 01:33 PM
Elisabeth Hunt's Avatar
Default EVIC compass: busted, or I am too dumb to figure it out?
I just purchased a 2008 T&C and I love it. However, my EVIC is not displaying the compass. Instead I see
-- 40o
(two dashes, and the outside temperature.) The steering-wheel-mounted buttons do seem to work - e.g. I can use the left button to get to things, and the right one to change them - EXCEPT when I try to change the compass variance, the right button doesn't work. The variance is stuck on 1. When the display said
COMPASS
CALIBRATE
>YES
I pushed the right > button, which put it back to the -- 40o display. I drove in a slow 365o circle several time, but it didn't change.
FWIW, the direction DID display during the test drive; it went away at some point while I was playing with the buttons. Any ideas how to fix this?
Old Mar 28, 2013 | 05:33 PM
Djinn-n-Tonic's Avatar
Open the hood, remove BOTH battery terminals.....Touch them together for 10 seconds, and then reconnect the battery.
Your compass has a "Brain" which is linked to the rest of the Brains in the car via a communication network, or BUSS. Any abnormality on the network will disable the "Brains, either individually or collectively. If restoring the battery doesnt clear the buss abnormality, Then further diagnosis will be required.
Old Mar 31, 2013 | 06:11 PM
Default no luck
Well darn, that didn't work. To the mechanic it goes! Thanks anyhow.
Old Apr 3, 2013 | 10:48 AM
Smile Just a fuse!
Turns out it was just a fuse. Easily fixed!
Dank442
Aug 7, 2014 08:04 PM
antiflag22skate
K-Cars
Oct 31, 2012 08:33 AM
usdiner
Jan 27, 2012 05:00 PM
ihatemychrysler
Aug 20, 2011 11:15 PM
antiflag22skate
Jun 2, 2011 07:48 PM
