Failed NJ Emissions...
Old Jan 11, 2009 | 03:41 PM
tc2005's Avatar
Default Failed NJ Emissions...
NJ Inspection station reported the computer can not be read, therefore no emissions data, FAIL.
Dealership said they couldn't do anything, do to no emission equipment.
Yes, I changed the battery. MONTHS ago. The EGR valve was recently replaced by the dealership it came, because of a leak that was noticed prior.
The check engine light flashes 10 times after 15 sec off the ignition in ON. Manual says go to dealer
Old Jan 12, 2009 | 07:32 PM
ghlkal's Avatar
Default RE: Failed NJ Emissions...
Is the check engine light on after it starts?
Will NJ not perform a tailpipe emissions test if the readiness indicators aren't set (assuming this is your issue)?
Old Jan 12, 2009 | 08:50 PM
tc2005's Avatar
Not sure. My poor wife was the one that took it down there. It sounds as if they gave her the run around.
I believe it goes by year, make, and model. They may need to see data from the OBD to determine emissions in addition to tail pipe.
I am guessing here.
So when they plugged into the OBD port all they got was the "not ready" signal, and no the engine light is off when fully started.
I am planning on taking it to a Chrysler Dealership next week unless someone hear has a better idea.
fmendez65
Mar 10, 2014 10:13 AM
mbabs1234
Nov 5, 2009 05:44 AM
roy.rut
Nov 1, 2009 07:30 AM
ctlo003
Jul 13, 2007 05:24 PM
Mar 11, 2006 12:12 AM
