Faulty speedo in 02 Grand Voyager.
The speedometer in my 2002 Grand Voyager suddenly stopped working yesterday and just stayed at 0. All other gauges seem to be working fine.
Want to determine if it could be something minor that I could fix myself before going to the dealer and handing over my first born. Any tips? |
If you also have shifting problems consider changing the output speed sensor. Try an instrument cluster self test to determine if the speedo itself is good. Here's how:
DIAGNOSIS AND TESTING - SELF-DIAGNOSTICS The instrument clusters are equipped with a self diagnostic test feature to help identify electronic problems. Prior to any test, perform the Self-Diagnostic Test. The self diagnostic system displays instrument cluster stored fault codes in the odometer display, sweeps the gauges to the calibration points, and bulb checks the warning indicators. When the key is in the ON position with the engine not running, the MIL will remain illuminated for regulatory purposes. To activate the Self-Diagnostic program: With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button. Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2) appears in the odometer window then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display “end” in the odometer display. Refer to the INSTRUMENT CLUSTER DTC'S table to determine what each trouble code means. INSTRUMENT CLUSTER DTC'S DTC DESCRIPTION 100.0 LOOP-BACK FAILURE 100.1 ABS COMMUNICATION FAULT 100.2 BCM COMMUNICATION FAULT 100.3 EATX COMMUNICATION FAULT 100.4 FCM COMMUNICATION FAULT 100.5 ORC COMMUNICATION FAULT 100.6 SBEC/DEC/MCM COMMUNICATION FAULT 200.0 AIRBAG LED SHORT 200.1 AIRBAG LED OPEN 200.2 ABS LED SHORT 200.3 ABS LED OPEN 200.6 EL INVERTER TIME-OUT 200.7 EATX MISMATCH 400.0 EEPROM READ/WRITE FAILURE 400.1 IMPROPER POWER DOWN DETECTED CALIBRATION TEST The CLUSTER CALIBRATION table contains the proper calibration points for each gauge. If the gauge pointers are not calibrated, a problem exists in the cluster. If any gauge is out of calibration, replace the cluster. CLUSTER CALIBRATION SPEEDOMETER CALIBRATION POINT 1 0 MPH (0 KM/H) 2 20 MPH (40 KM/H) 3 60 MPH (100 KM/H) 4 100 MPH (160 KM/H) TACHOMETER 1 0 RPM 2 1000 RPM 3 3000 RPM 4 6000 RPM FUEL GAUGE 1 EMPTY 2 1/4 FILLED 3 1/2 FILLED 4 FULL TEMPERATURE GAUGE 1 COLD 2 1/4 3 3/4 4 HOT ODOMETER SEGMENT TEST If a segment in the odometer does not illuminate normally, a problem exists in the display. ELECTRONIC TRANSMISSION RANGE INDICATOR SEGMENT TEST If a segment in the transmission range indicator does not illuminate normally, a problem exists in the display. __________________ Thanks to Master Tech at www.dodgeforum.com for posting |
Thanks, just ran the diagnostics and it didn't display any error codes.
However it seems to have reset something as the speedo has started functioning again.... |
Maybe it just needed waking up. Good news.
speedo stopped working
Well done
I had same problem and found out how to fix You have to reset the speedo by pressing in the the button on the speedo and all the light light up on dash and resets itself. Just for future reference. |
Originally Posted by fattylady
(Post 58051)
Well done
The speedometer in my 2002 Grand Voyager crd suddenly stopped working and just stayed at 0. All other gauges seem to be working fine.
I have 2 codes on my test; 100.5 orc communication fault, 100.4 fcm fault. What dose FCM AND ORC Mean and how do i fix this problem, can any one help please. |
Hi sorry for jumping in 2 years later but I also have the same problem. Ive done the reset and got no error codes but it hasn't reset the speedo ( it's still not working) The rest of the instrument is working fine. Is it worth just replacing the cluster or do you think it could be donething more?
| All times are GMT -5. The time now is 02:17 AM. |
