Fob key stopped working
Hey
I unlocked my Voyager -12 as usual with the remote key and everything seems fine but when I tried to start my car nothing happened. The lights (beams), inside light works. I can even open and close the doors with the inside button in the car. But i can nolonger lovk or unlock the car with the keys. And when I try to start the engine nothing happens. I have changed battery in the key and even tried the reserve key.
Anyone who have a suggestion of what i can try?
Best regards
Fredrik
Best regards
Fredrik
If it cranks but not start check if fuel pump is running. I had similar problem with my 2012 T&C and it was a faulty TIPM . I purchased a bypass module and problem solved. Good Luck
Best regards
Fredrik [/QUOTE]
Best regards
Fredrik [/QUOTE]
Best regards
Fredrik
Best regards
Fredrik
Sorry to say that I came to this forum looking for info on a very similar problem with my 09 town and country but thought it wouldn't hurt to at least mention that somewhere online I read a trick to get some vehicles to recognize keys fobs again is to turn your fob to the on position but not all the way to start and leave there for 30 minutes, then turn to off and wait 30 seconds so this 3x on for 30 minutes off for 30 seconds on 30 minutes off 30 seconds on 30 minutes off 30 seconds then start the car. Good luck. I would also recommend looking under your dash for any kind of aftermarket gps tracking devices that may have been put there by former owners or car lots. If you find one than it is possible that you have been locked out by that device.
Best of luck to you.
loyercorey
Aug 20, 2018 05:23 AM
