Front air vents/blowers not working - Grand Voyager 2003
Hi, hoping someone might have an idea about this. I've actually had this problem for few years, but I've now decided to do something about it. Takes a while for my impatience to kick in.
I searched the forum and found a pretty identical issue to the one I have that was posted over 5 years ago. However it didn't receive any responses so I'm hoping this isn't that unique a problem any more. That post is here: https://www.chryslerforum.com/forum/...h-board-18806/ My problem is pretty much the same. I cannot get the front air blowers/vents to work. The air con works and heating fine, and air will come out out of all other vents. Windscreen, rear, floor etc. No matter what I set things to, the front vents on the dashboard (not the windscreen vents) will not blow air. Whatever it is that controls them, doesn't kick in. I can switch all the other vents/blowers on and off, and I can choose between standard air flow, air con or heating, and temperature control is fine, but those vents just won't allow any air through. Any ideas? Any help appreciated. |
If it's any help, I remember a couple of months ago somebody had a similar problem which was caused by leaves/twigs in the intake which had jammed the flaps on the blower.
