Front lower suspension arm bush replacement
My 2.8 CRD has been clonking over bumps for quite a while now.
Just had it MOT'd and it passed, but with advisories that both front lower suspension arm rear mount bushes are deterioted. Also one of the sway bar bushes are deterioted (no surprises there) Have any of you replaced the lower arm bushes? Do they need pressed in or are they fairly easy to replace? |
the front arm rear bushes are easy there is a metal sleeve inside the bush which can get stuck on the arm on the later cars 2001-
the earlier voyager are just rubber be careful if buying off ebay there is a guy in latvia he is the one to buy from thats where i got mine from |
Thanks for that Dan. Mine is a 2004, so I'll bear in mind the sleeve getting stuck.
