fuel injector vacuum leak
Old May 4, 2014 | 11:06 PM
davet's Avatar
Default fuel injector vacuum leak
2000 T&C with 3.8, 201,000 miles. Yesterday noticed poor tranny performance, sluggish, chugging off line and chugging in reverse. Audible hissing at lower injector o-ring on rear driver's side injector. I sprayed the base of that injector with carb cleaner and hiss stops and idle drops. I think this is source of tranny issue as it's a brand new tranny with about 10,000 miles on it.
Can I change the seals without removing upper manifold? Seems hard to get at the injector clips with manifold in place. I know sometimes you need to lightly tap the fuel rail with rubber hammer on a block of wood to get them to seat in the manifold. None of the injectors are leaking and she runs like a top otherwise. Should I change all injectors while I'm at it? Any tips on the intake manifold gaskets?
skylinefeb75
Apr 22, 2013 05:48 PM
funjon1
May 6, 2011 06:24 AM
ausable1854
Sep 25, 2010 01:23 PM
Oldbazzer
Aug 17, 2009 10:39 PM
anrie
Jun 11, 2008 09:54 AM
