gearbox drain plug 2.5crd
can anyone advise where the drain plug is on a 2.5crd
need to change the oil as i believe someone has put the wrong oil in it looking through reciepts when the clutch was done looks like they put 75w 90 in it dan |
found it all done ,deffo had the wrong oil in it goes into gear so much easier and my juddering has gone
Hi
What oil did You use for it and how much? thanks |
it uses atf (auto trans fluid) and capacity is just under 3ltrs
has amde a big difference to mine had quite a lot of clutch judder this has now almost gone getting into gears is alot easier although it can still be a little difficult occasionly think i will drain and refill again considering it had 75w90 in it |
