gearbox drain plug 2.5crd
Old Apr 8, 2011 | 12:39 PM
voyager_dan's Avatar
Default gearbox drain plug 2.5crd
can anyone advise where the drain plug is on a 2.5crd
need to change the oil as i believe someone has put the wrong oil in it
looking through reciepts when the clutch was done looks like they put 75w 90 in it
dan
Old Apr 11, 2011 | 03:56 AM
found it all done ,deffo had the wrong oil in it goes into gear so much easier and my juddering has gone
Old Apr 22, 2011 | 02:28 AM
Motormouce's Avatar
Hi
What oil did You use for it and how much?
thanks
Old Apr 24, 2011 | 04:02 PM
it uses atf (auto trans fluid) and capacity is just under 3ltrs
has amde a big difference to mine had quite a lot of clutch judder this has now almost gone
getting into gears is alot easier although it can still be a little difficult occasionly think i will drain and refill again considering it had 75w90 in it
darkcild101
Jun 22, 2015 06:50 PM
cullymc
Sep 13, 2013 01:34 AM
GsiDaz
Feb 11, 2013 03:46 PM
fujirio
Mar 20, 2010 12:52 PM
VFRbeliever
Cirrus & Breeze
Dec 8, 2007 01:30 PM
