gearbox seal blown
Hi, further to my LOSS OF GEARS post, i have replaced rad and gearbox, driveshaft seal was leaking so removed shaft and "flange plate" that has 4 bolts top and 2 bolts bottom. i replaced the seal that you can see when shaft is removed,
QUESTION.....is there more than one seal inside this flange plate? After putting it all back together and on a test drive seal has blown out, i had trouble getting old seal out almost as if it was "GLUED" in, should i have glued the new one in, if so with what? or is there something else i have done wrong hoping for advice regards john |
so removed shaft and "flange plate" that has 4 bolts top and 2 bolts bottom. i replaced the seal that you can see when shaft is removed, Houston...we have a problem...... That flange plate is the carrier for the differential bearings......If it doesnt sit properly, the shaft "WALKS" in and out and drags the seal with it...... It will probably need to go to a Trans guy , to have the diff set up again..... |
gearbox seal
hi djinn,
obviously i bow to your superior knowledge, but the plate can only go back one way and i know it was bolted up as tight as it came off,is there any other reason?, when the seal blew i had just driven up a steep hill, would that have put the box under greater pressure? respectfully john |
Originally Posted by john franklin
(Post 52056)
hi djinn,
obviously i bow to your superior knowledge, but the plate can only go back one way and i know it was bolted up as tight as it came off,is there any other reason?, when the seal blew i had just driven up a steep hill, would that have put the box under greater pressure? respectfully john I'm just about to replace the N/S drive shaft oil seal on my 03 voyager. Do you have any useful tips you would care to tell me about. It's nearly 40 years since i was on the tools and it the force of the economy which has taken me back to them. best regards Les |
hi lesF, it is really quite straight forward, all i would say to take care about is making sure the drive shaft is properly engaged and fully home,i had someone fit my replacement box and he said that the seal was weeping, so when i took the shaft out to replace the seal i put it back the way it came out,not realising my fitter hadnt put it in right originaly,i only found this out when i changed the offside,so then had to go back and refit the n/side but it did cure my leaks,
so best of luck hope this makes sense and helps regards john |
| All times are GMT -5. The time now is 02:38 AM. |
