Got a P0123 code
Old Aug 3, 2010 | 06:54 PM
Army_guy's Avatar
Default Got a P0123 code
I have a P0123 code and am not sure how to fix it. (3.8-2002-town and country) It give me a 4.5 volt reading when the throttle is closed and i understand that it should be .5 volts. And when i turn the throttle to WOT there is no change. (Put a new sensior in, no change) There is good continuity for all 3 wire coming out of the TSP sensior to the PCM. Not sure where to go from here. The car runs and drives, but has stalled in the past due to this problem.
Old Aug 5, 2010 | 06:48 AM
Army_guy's Avatar
Still working on this problem, the car is running now and has yet to stall sence I cleaned all the sensiors (O2, TPS, and MAP) but the reading are still all the same, and the P0123 is not going away. Really stumped---Starting to think of changing the harness, but still not sure if thats going to do anything! Would really like so help here.
Old Aug 5, 2010 | 06:52 AM
Army_guy's Avatar
(Forgot to add to the last reply)
Also I noticed that my cruise control has stoped working, could this be apart of the same fault, or do I have a whole new set of problems?
Old Aug 5, 2010 | 08:52 AM
with the key on unplug the TPS
using this wire diagram measure and tell me what U get
THROTTLE POSITION SENSOR (GAS) - GRAY 3 WAY CAV CIRCUIT FUNCTION
1 K900 18DB/DG SENSOR GROUND (60 ohms of resistance )
2 K22 18BR/OR THROTTLE POSITION SENSOR SIGNAL (5V)
3 F855 18PK/YL 5 VOLT SUPPLY (5V)
bradneal
11
Nov 28, 2007 09:11 PM
KCustom
Jan 26, 2006 04:15 AM
87ram
Oct 28, 2005 03:19 PM
RaceDeck
Jul 29, 2005 11:42 PM
redriderbob
Dec 11, 2004 05:11 AM
