GRAND VOYAGER GROWLING
Old Dec 1, 2008 | 12:12 PM
craigdjdj's Avatar
Default GRAND VOYAGER GROWLING
hi can anybody help me i have a grand voyager 3.3 limited on a 51/2001 plate:
when the engine is started it(ON OCASSIONS)makes a whining growling sound.
no warning lights etc come on neither does it run hot. infact is a brilliant runner.
the sound does not run for longer than 5/7 seconds but is quite loud.
does not sound like fanbelt slip. and does not result in any flashing lights on the dash?
any ideas?
can anyone help or advise me.
THANKS CRAIG THE BRITISH GUY.
Old Dec 1, 2008 | 08:45 PM
dodgetech1's Avatar
Default RE: GRAND VOYAGER GROWLING
My guess would be a/c compressor or clutch.
Old Dec 2, 2008 | 10:09 AM
craigdjdj's Avatar
hi thanks for that have priced one up.
( is that the air conditioning pump clutch and pulley assembly?)
and is it a big job too do ?
thanks craig the british guy
Old Dec 2, 2008 | 11:31 AM
Merlin's Avatar
Hi
Pull on the belt and just make sure the auto belt tensioner is moving ok (not sticking) and is inline with the belt. Could well be the tensioner and it's belt noise (I know you said it does't sound like belt noise but is good to check) could even be the idle pulley. Is the noise coming from the belt end? or could it be the starter motor?
Old Dec 5, 2008 | 11:37 AM
rob131's Avatar
I have the same problem, only happens when its cold... I've replaced the steering pump, idler pully tensioner pully, and alternator. still trying to narrow this problem down.
Old Dec 5, 2008 | 08:56 PM
dodgetech1's Avatar
rob I would try replacing the belt, what does the belt look like?
Old Dec 28, 2008 | 08:53 PM
rob131's Avatar
yup i replaced the belt twice (different brands and qualities) to fix this.
far as i can tell its got to be either the ac compressor clutch bearing, the water pump or something internal. bought an ac clutch and am going to try that, any other help would be great.
Old Dec 28, 2008 | 11:14 PM
dodgetech1's Avatar
i would first remove the belt and spin everything to see if anything is rough.
Old Dec 29, 2008 | 12:25 AM
Moosetrax311's Avatar
i would remove the belt then start it up. obviously don't run it for to long. if the growling is not heard then ur problem is in the accessory drive belt somewhere. if it still does it i would start looking at the starter. i've seen starters stick and they make a growling noise when still engaged while the engine is running.
John
Old Jan 2, 2009 | 10:55 PM
rob131's Avatar
Hi, thanks to all that are trying to help me. heres the latest update.... I removed the belt and started it, no noise! then I replaced the ac clutch assy. still growling, then I just replaced the water pump (the only thing driven by the belt that I haven't replaced yet)... guess what, STILL GROWLING!!!!! I'm back to te power steering pump. is there any kind of check valve in the steering sytem that might fail, and let air back into system? when i changed the pump the first time, i turned the wheel lock to lock multiple times to bleed the system, is there anything more i can do to make sure there is no air in the fluid? thanks again to all those thatare trying to help me.
