hard starting
Old Aug 31, 2014 | 09:55 AM
davidgossett's Avatar
Default hard starting
This morning went out to go to church and my van just turned over. Know attempt to start just turned over. After several attempts it started and ran fine no codes. It is a 2009 town country 3,3 with 96,000 miles on it. Can someone tell me where to start? Any help would be appreciated. Thanks David
Old Aug 31, 2014 | 12:30 PM
What year and engine size do you have?
Next time around when u try and start and it wont stop then turn the key on and off 3x with out starting teh car then try it after that see if it will fire right up.
Old Aug 31, 2014 | 06:09 PM
Raptor 07's Avatar
If it starts fine after that process you have a leak in the fuel system that's depleting pressure either in a line, the pump assembly in the tank or a fuel injector. See or smell any evidence? Cycling the key to on/run momentarily turns the pump on building pressure back up to specs. Many times the pump casing is cracked and leaking fuel on top of the tank or the pressure regulator on the pump assembly in the tank is leaking. Means a pump replacement.
Old Aug 31, 2014 | 09:07 PM
About a month ago we had an issue with it sounding like it was dieseling when started. I immediately turned it off and restarted it. It started fine but the service engine light came on. Took it by advanced auto to pull the code. The tech said that the code was classic for a loose gas cap. No problems since we tightened it. Until now. There is no smell of or visible gas that we can see. Could this be related to the gas cap? We just got back from a1700 mile round trip vacation(@850 one way). Gas mileage was great @22-23 mpg on hwy. No other issues. Any ideas or suggestions would be greatly appreciated.
David
Old Sep 1, 2014 | 11:40 PM
you still did not answer the question and no the gas cap code will have nothing to do with starting your car.
Old Sep 2, 2014 | 06:36 AM
What question are you talking about the one about motor size and stuff? That's in the bottom of my first post. Thanks for looking greatly appreciate your help David.
Old Sep 2, 2014 | 10:14 PM
right below me asking the year make and model
Old Sep 2, 2014 | 10:32 PM
Sorry yes turning it off to on the 3 times and it started great. Sorry for the miss communication. Thanks David
Old Sep 4, 2014 | 04:37 AM
then u have a fuel pump that is not holding pressure if u see no outside leaks or u dont smell gas then the pump is leaking back down thus why it take awhile to start up.
Old Sep 4, 2014 | 06:23 AM
Knowing it is the pump, how hard is it to replace is it something that can be done at home or at a dealer? And the big question if I have it done at the dealer or repair shop about how much? Thanks for all the help y'all have been very helpful. David
