Headlining Adhesive.
Old Jun 10, 2016 | 03:24 PM
Default Headlining Adhesive.
How many times have I looked at it and said, "need to sort that, stick it up, next time next time", but it never comes. Then when you decide to do it, what glue will I use that won't melt the deadening material above or discolour the lining. So what's the story or the answer guys.
Old Jun 10, 2016 | 03:53 PM
Vmaxxer's Avatar
I used Bison kit spray can on my Mercedes roof but that did not work at all.
After that I used Pattex High Tac and that worked perfectly well
Old Jun 11, 2016 | 08:55 AM
Perhaps a spray on carpet adhesive will do the strick.
Old Jun 11, 2016 | 04:05 PM
Yes I'm looking into spray carpet adhesive it came up on the last thread for is issue.
Old Jun 11, 2016 | 05:45 PM
Vmaxxer's Avatar
Beware if the spray adhesive is like a thin layer when applied, it will have not enough "body" to keep the lining up.
Like I said, Bison kit spray glue doesnt work because of that.
Old Jun 12, 2016 | 06:34 AM
Bee's Avatar
Bee
With most carpet adhesive you spray both surfaces and leave until its tacky like contact adhesive. and WD40 will remove any over spray.
darkcild101
Jun 14, 2016 03:59 AM
USA300AUS
Dec 14, 2014 02:00 PM
KYBarrister
Nov 1, 2009 06:02 PM
