How hard is it to replace condenser?
Old Nov 9, 2010 | 02:11 PM
Kaysvan's Avatar
Default How hard is it to replace condenser?
I have 2005 T&C Limited and driver side is blowing warm as passenger side is cold. I do believe it is the condenser leak. Is this something DIY can be done?
Old Nov 9, 2010 | 10:54 PM
TNtech's Avatar
Why would you think it's a condenser leak if one side is till blowing cold? You have a problem with your blend doors or the actuators...maybe even the control head. A dash pull is not a DIY job usually.
Old Nov 10, 2010 | 06:12 AM
Kaysvan's Avatar
I thought it was blowing one side cold, but it is warm both side. I just replaced the rear evaporator and need to pull the condenser to replace. It seems the freon has escaped since it is blowing warm and the compressor is not kicking in due to low or no pressure.
Old Nov 10, 2010 | 09:28 AM
look at the lower left hand side of the condenser if it is wet its is leaking
Old Nov 10, 2010 | 12:30 PM
Kaysvan's Avatar
Default Condenser
Well, I went to the dealer because of the AC issue, and they found out that the rear evaporator and front condenser were leaking. I had a local mechanic replace the rear evaporator and he told me the only thing leaking on the condenser was the O rings. Maybe it is not the condenser that is leaking... BTW, dealer did put the dye in and that is how they found out about the condenser and evaporator leak.
Old Jul 6, 2011 | 08:43 AM
Jacob25crd's Avatar
Default how to remove fascia grill
I have exactly the same question.
I believe the answer is here:
2002 Chrysler Town And Country Condenser Replacement
Has anybody done this recentlty? In particular: The text does not say that the front fascia grill must be detached from the bumper. Is this correct or merely assumed self-evident? If the fascia grill needs to be removed, how can I get it apart from the bumper?
Old Jul 7, 2011 | 09:33 AM
TNtech's Avatar
Jacob, on just about everything we have I remove the fascia. I don't like to fight and bend things and shove my hand and forearm into tiny places. The extra 15 or so minutes pulling it off will reap BIG rewards in the frustration dept. lolz
Fascia and bumper are the same piece. Some push pins along the bottom and a screw or two behind the inner fender shield that attch it to the fender.
Old Jul 7, 2011 | 11:11 AM
Jacob25crd's Avatar
Ok thanks this is helpful.
I thought "fascia" meant only the grillle between the headllamps.
I had been tempted to remove the bumper but did not dare at the time. I will now have a new go at it.
Thanks.
Old May 26, 2013 | 08:59 AM
bertrobinson7's Avatar
98 Chrysler Concorde 3.2 engine AC condenser replacement instructions.
Can anyone help me
Old May 26, 2013 | 09:04 AM
Default 98 Concorde 3.2 engine AC condenser replacing
AC condenses reportedly leaking and a vacuum cannot be pulled.
I have new condenser but had no instructions on the installation procedure.
Can anyone help me?
