How to program a NEW key fob?
I've just bought a brand new key fob(As we only ever had one) and was wondering if there was anyway In programming it without going to the main stealer? Also we have one key, so would need a new one! Do the keys have a transponder in them? Or can I just get one cut at Timpsons?
Cheers Tim |
What year is your car? I Found this:
2002 Chrysler Town and Country Key Fob Remote Programming Instructions Here are the programming instructions for a 2002 Chrysler Town and Country Key Fob Remote. If you need an extra Key Fob or Replacement Fob for any vehicle you might have visit us at Keylessentryremotefob.com You can also leave comments or suggestions at the bottom of this blog and if you like what we provide please forward on to your friends & family; people like you are our best advertising tool! ORDER THIS KEY FOB PART NUMBER HERE: 04686481AA or 04686797 or 04686481AB ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you. 1. Press LOCK button 5 times at 2 second intervals to re-synchronize remote. 2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can go without cranking engine). Wait for ignition chimes to stop. 3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10 seconds. 4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then press the PANIC button ( on the programmed remote ) for 1 second and release both buttons. A chime will sound to indicate that the remote programming mode has been entered ( allow 3 seconds for chime to sound ). 5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons simultaneously then press and release just the UNLOCK button on the same remote. A chime will sound indicating the remote has been programmed. Press and release the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on each new remote you wish to program at this time. A chime will sound after each additional remote is programmed. 6. Turn the ignition OFF and remove key. 7. Test Remotes. |
Hiya...
Many thanks for the info :) My car is a 2007 year on a 56 plate. Hopefully this will work! I was going to try it now! But there is a very large thunderstorm on its way! Wind has picked up and a sudden drop in temperature! Exciting stuff! Time to get my twin boys in... |
Does the 2001 model have a panic button
No EURO FOB has a sixth button
I bought a 6 button case & blade from this bloke as an experiment on the 'panic' button programming. His Chrysler stuff is here. The pcb from our standard 5 button fob has the 6 button internals which are complete and do fit ok. The problem I had was that there is an internal [Cellophane like] 'conductive tracked membrane' for all 6 micro switches which corresponds to the 6th button which I can't seem get hold of in the UK. In conclusion the 6th button is on our fob's, the 6 button key can be bought for £4 above, the 'tracked membrane on our UK version is missing the track that connects the existing 6th micro-switch. The 'locked' [to Chrysler] ID46 transponder chips are widely available, don't make the mistake of buying the commonly available peugeot one - they may be [locked] different. Regarding the 6 button FOB's, like yourself I have never managed to find one in the UK. I did find the 6 button Blank Blade Remote Key Case shells here in the UK. Your PCB will go straight into the FOB and the panic button will be in the correct place directly over the micro button but will still not work. What's missing is the etched (1) conductive membrane that goes between the (2) PCB and the (3) FOB shell to translate the KEYPRESS. In short unless you can get the conductive membrane that goes between the PCB and the FOB shell you still cant make a keypress. The combination key & FOB with the 6th button can be had from America such as this one here. - I know that the existing UK FOB has all the 6 button microswitches, but only a 5 conductive tracked membrane - I make the assumption that any 6 button FOB or keyFOB [remote head key] shell is just that a shell - you can transfer the internals along with the 6 microswitched PCB a from 5 to 6 button FOB but only 5 buttons will work http://i.ebayimg.com/00/s/MTE5MlgxNj...CwQ~~60_57.JPG What I have always assumed will work [forget the grey transponder key for the minute] is get a second hand complete with conductive tracked membrane fob from America ebay, then transfer your existing 6 button EURO PCB into the 6 button panic fob complete with its conductive tracked membrane and you have a working and programmable 6 button FOB. If you take apart your existing 5 button UK or EURO FOB you will find you have a complete 6 microswitched PCB with only 5 'traced' conductive tracked membrane. Programming is here. |
Originally Posted by QinteQ
(Post 81070)
I bought a 6 button case & blade from this bloke as an experiment on the 'panic' button programming. His Chrysler stuff is here. The pcb from our standard 5 button fob has the 6 button internals which are complete and do fit ok. The problem I had was that there is an internal [Cellophane like] 'conductive tracked membrane' for all 6 micro switches which corresponds to the 6th button which I can't seem get hold of in the UK. In conclusion the 6th button is on our fob's, the 6 button key can be bought for £4 above, the 'tracked membrane on our UK version is missing the track that connects the existing 6th micro-switch. The 'locked' [to Chrysler] ID46 transponder chips are widely available, don't make the mistake of buying the commonly available peugeot one - they may be [locked] different. Regarding the 6 button FOB's, like yourself I have never managed to find one in the UK. I did find the 6 button Blank Blade Remote Key Case shells here in the UK. Your PCB will go straight into the FOB and the panic button will be in the correct place directly over the micro button but will still not work. What's missing is the etched (1) conductive membrane that goes between the (2) PCB and the (3) FOB shell to translate the KEYPRESS. In short unless you can get the conductive membrane that goes between the PCB and the FOB shell you still cant make a keypress. The combination key & FOB with the 6th button can be had from America such as this one here. - I know that the existing UK FOB has all the 6 button microswitches, but only a 5 conductive tracked membrane - I make the assumption that any 6 button FOB or keyFOB [remote head key] shell is just that a shell - you can transfer the internals along with the 6 microswitched PCB a from 5 to 6 button FOB but only 5 buttons will work http://i.ebayimg.com/00/s/MTE5MlgxNj...CwQ~~60_57.JPG What I have always assumed will work [forget the grey transponder key for the minute] is get a second hand complete with conductive tracked membrane fob from America ebay, then transfer your existing 6 button EURO PCB into the 6 button panic fob complete with its conductive tracked membrane and you have a working and programmable 6 button FOB. If you take apart your existing 5 button UK or EURO FOB you will find you have a complete 6 microswitched PCB with only 5 'traced' conductive tracked membrane. Programming is here. Great post mate. So is the method talked about above the correct way of doing it as mine is a genuine new UK fob? . Also it looks like there isn't a transponder in the separate key if you can buy a fob with a blank blade. Is this correct? |
1 Attachment(s)
Yeh so are my two FOBS, the one single item, needed for myself is the '6 conductive tracked membrane' - all the UK and as far as I'm aware all EURO FOBS are 5 button and 5 'conductive tracked membrane's' but they all have 6 micro-switch internals. What you and I want is the membrane with the 6 tracks on it. If you take apart your existing FOB you will find you have a piece of PCB with the complete 6 micro-switches. The picture below shows a bog standard EURO fob without a panic button .. .. .. but with the already present 6 micro-switches.
For example also if desired, the "Sound Horn On Lock" feature can be turned on and off by performing the following procedure: 1. Press the LOCK button for 5 to 10 seconds. 2. While the LOCK button is pressed (after 5 seconds), press the PANIC button. Release both buttons. The "Sound Horn On Lock" feature can be reactivated by repeating this procedure. Attachment 2416 |
So what does panic button do
Chrysler and Dodge vehicles from the 2005 timeframe use a keyless entry system developed originally for the Mercedes brand. The system actually implements the driver convenience and safety functions, an immobilization function designed to prevent vehicle theft, and sets the alarm state off and on. Different buttons on the EURO FOB variously :
- lock and unlock all doors on the vehicle, or drivers door only - one [not in the UK or Europe] is a panic button that can be pushed to sound an alarm - one is power lift [boot] gate - one each for both left & right motorised sliding doors What the panic button does is allow a user to program up to 4 different transmitters, in order to do this the panic button needs to be used. |
Oh right... complicated stuff me thinks! But as long as I can programme the new remote! Thats all I'm really bothered about! :)
