Inefficient rear brakes?
Old May 8, 2011 | 04:26 PM
Alexmartuk's Avatar
Default Inefficient rear brakes?
Hi All
I have a '99 2.5TD owned since new. A real love/hate relationship I have to say!! The problem I have is for the last 2 MOT's, the rear brakes have failed the efficiency test. This is not apparent until the tester puts the figures into the system. On both occasions, the 'rolling road' test appears within limits and the tester is happy with results. We have managed to get it to pass by pumping/pressing hard on the brake pedal. Have replaced shoes and brake cylinders but no real change noted. Does anyone know if the brake proportioning valves could be the problem and any way of testing them?
Many thanks
Old May 10, 2011 | 08:13 AM
ettienne's Avatar
Drum brakes in the rear?
Have you tried bleeding the brakes to see if that helps?
Old May 15, 2011 | 02:14 PM
Alexmartuk's Avatar
Yes, done a brake system bleed several times.
gareth111278
Jul 15, 2010 03:08 PM
Docfausset
Feb 23, 2010 09:36 PM
3.3lxbluevan
May 2, 2009 06:34 PM
sebring04
Apr 2, 2009 08:40 PM
3.3lxbluevan
11
Feb 15, 2008 04:32 PM
