injector change solves rough idling when hot, black smoke when accelerating
Well, finally resolved the black smoke and rough idling issues that I have been struggling with. I am posting this as a new thread, as there are many other threads on black smoke and rough idling and this one is more on the changeover of injectors.
Up until the final resolution - I had tried the following:
Despite warming the engine, using penetrating spray over a few days and an air powered torque wrench, the first injector did not budge at all. The hook shaped puller stretched and got distorted with nary a scratch on the Bosch injector. At this point the puller was useless. I am glad that the puller broke - the last thing I would have wanted was for the puller supports to crack the cam cover. Finally took it to the local garage. The mechanic spent 3-4 hours with a 5kg slide hammer to remove all four injectors...! He refused to use the hydraulic puller due to risk of cracking the top cover of the motor. After months of trying this and that, the car idles well and smokes no more. I did not use new fuel pipes as recommended by the dealer. If you are careful and use plugs and keep the area clean, it's ok. Takeaways:
Thanks, kkc. ;) |
Does anyone know if the 2002 engines used computer coded injectors - tfb will no doubt spot this post shortly and will confirm either way for you puller stretched and got distorted - that would take a lot of doing, but better than fracturing the cam cover - good tip then from you on 'slide hammer' v other puller |
Just wondering if injector would come out eventually by torqueing up puller, applying release oil and leaving overnight. Its not just Chrysler VM's that have this problem. Was talking to a mechanic today and he was having trouble pulling Peugeot 1.6 injectors.
Looks a sturdy puller that BGS one. |
Originally Posted by goggs
(Post 87301)
Looks a sturdy puller that BGS one. - but it stipulates for VM specific engines, which is why I was asking |
Injectors don't need coding
Regards Richard |
Thanks tfb... for the confirmation on coding. The garage I went to specializes in diesels and he confirmed to me that a lot of motors, irrespective of make, have seized injectors.
QuinetiQ - yes, the puller stretched and got distorted as I was tunring the torque not on top of the BGS puller. The hook area that pulls up the injector just got squeezed is now pretty much useless. I did think about leaving the puller on overnight. However I am not convinced that the release oil soaks down as far as the copper washer - it's 8-10 cm. I suppose if they go down 30% that's 30% release. Worth a try. In my case, the injectors were rusty all the way down - rust and brown colouring. The impact wrench I applied was so powerful that it was shredding bits of metal off the BGS torque nut. Thankfully no pieces entered into the fuel intake port of the injector as I had removed the high pressure pipe. I think what is needed with these injectors is impact energy - powerful bursts of energy to release and pull them out. A constant overnight pull from the puller will probably not be enough. One other option I tried was to turn the clamp bolts lefty-loosy about two turns and then let the motor run at about 1500revs for a few mins to see if piston pressure would do the trick. Didn't work! Maybe a short uphill drive might have done the trick. |
Not sure whether it's been the impact wrench or the BES puller, but 40-50 injectors removed by the genuine Miller Tools puller cant be wrong.
Normally needed a 2ft breaker bar, or a ratchet with a scaffold pole, but slow and steady wins the race. Any 4 injectors, 20 mins, guaranteed. I went to a guy that had tried removing the injector clamps then having a good run up and down a dual carriageway. Dont know the RPM but sure it was more than 1500. Didnt budge them. |
Couple of questions sir
1. How much was the leak back test 2. How much did you pay for fitting of new injectors |
I wouldn't go for impact tools either. Slow steady force is required and plenty of the correct grease around the injectors when refitting
Regards Richard |
If I remember there a video on You Tube of 1 or 2 guys standing on the engine of a CRD voyager and removing the injectors with a huge slide hammer tool...Couldn't quite believe it needed that tool to get them out...
