injector seal fail...
Old Oct 20, 2014 | 05:50 AM
TimmyTim's Avatar
Thumbs up injector seal fail...
Our 2007 2.8L oil burner has an injector seal blowing! I can hear it and started to smell the fuels coming into the cabin. Anyone know if these "O" rings are either copper or Aluminium? The reason why I ask is that Toyota had problems on there Land Cruisers due to them fitting the wrong ones that reacted with the fuel and caused engine failure.
Old Oct 20, 2014 | 08:02 AM
TomC's Avatar
Just had 4 recondition injectors put in my 2.5 CRD and the seals that came with the injectors and were fitted by the garage were copper and none have failed for me touch wood
Old Oct 20, 2014 | 08:09 AM
TimmyTim's Avatar
Thats good to hear they were copper. Out of interest, how much was it for the 4 recon injectors?
Old Oct 20, 2014 | 09:26 AM
TomC's Avatar
I paid £150 each service exchange (had to give them my old ones otherwise £210 each
there are some on an auction site £89 each tested I ve bought from this guy before and he is really reliable PM sent
Old Oct 20, 2014 | 01:46 PM
Just like 3000hp Diesels they use copper washers too, annealed washers that is. Use only once unless you reface them and anneal again. Not worth the bother though.
Old Oct 20, 2014 | 01:47 PM
TimmyTim's Avatar
Pm sent mate
Old Oct 20, 2014 | 01:50 PM
TimmyTim's Avatar
Thumbs up
A new one was used mate. Not worth the myther for £3.30.
Old Oct 20, 2014 | 05:20 PM
Scotsman4th's Avatar
Not for the Voyager, but when I bought new bits for the injectors, I got copper washers and something similar to this....
FEBI O-RING Skoda Yeti 2009- VW Voyage 2008- VW Voyage 1994-08 VW Voyage 1 33672 | eBay
Old Oct 22, 2014 | 07:33 PM
TimmyTim's Avatar
Cheers Scotsman for the link. Well s quick update on the seal. Looks like its holding a in the gasses and the engine is running as sweat as a nut! Now that the new alternator is on and the power steering belt and Aux belt change. The tensioner was done at same time, so was the idle roller. Gotta love these VM Motori Marine diesel engines...
Old Jul 7, 2016 | 12:51 AM
Andrips's Avatar
I am after some advice.
Got two used injector from a friend who scrapped his car. The questions are how to store them. I'm not sure that I need to change them, but I took them as a spare for future. I was thinking about keeping them in acetone (when plastic parts removed). Any ideas?
Other worry is that they damaged the thread a little bit . Will I have a problems to install them?
