Installing exhaust camshaft locking pin 2.5 CRD 12/2002
Old Sep 8, 2013 | 11:01 AM
kkc's Avatar
kkc
Default Installing exhaust camshaft locking pin 2.5 CRD 12/2002
Hi
I am about to do a timing belt change on my Voyager 12/2003 2.5 CRD. I have managed to lock the inlet cam, the flywheel but can't figure out how to get access to the exhaust plug which needs to be removed so that the exhaust cam can be locked.
The area is very tight with what seems to be an exhaust pipe attached by a bracket to the engine block. The problem is that there's very little room between the firewall and the exhaust side of the engine (engine is fitted transversely).
Note, I do need to remove the cams... as I am also changing the water pump.
Any ideas? Thx. kkc.
Y4J
Jan 31, 2023 06:33 AM
Jonieshilo
May 20, 2018 04:20 AM
t&c2006
Aug 26, 2013 09:16 AM
Jem11363
Mar 13, 2012 06:07 AM
morgoth
12
Dec 31, 2010 05:39 PM
