Intermittent air bag light issue, 2005 T&C
Old Mar 4, 2015 | 06:39 PM
dannyboyindc's Avatar
Default Intermittent air bag light issue, 2005 T&C
Hi everyone, first time poster, long time lurker. I'm hoping to get some advice from you all about an ongoing issue. Two years ago, a mechanic friend replaced the front rack and pinion and in the process damaged the clock spring (I'm assuming). I had the clock spring replaced and all was fine. Recently, the air bag light started going off and on again. There doesn't seem to be a rhyme or reason to it. The horn DOES operate. In fact sometimes, the air bag light goes off when I hit the horn (but not always, it's totally random).
Any ideas where I should be looking? Could the replaced clock spring be going out again, or it might be something else? I already had the recalled air bag switch replaced about 4 years ago. Thanks for any suggestions!
Old Mar 4, 2015 | 06:41 PM
get a scanner that's able to read air bag module and it will tell you what teh codes are better then guessing.
Old Mar 5, 2015 | 05:51 AM
Leedsman's Avatar
Something you can do for nothing and quickly without getting dirty.
Statistically the most common airbag-light-on cause is around the pre-tensioners. These may have fired under v. heavy braking. With a ruler, check the length of the coupling to the floor of each belt fastner. If one is short compared to the others, that's it. A 5-min diagnosis if you're in luck. Otherwise that's at least out of the way if ok.
Leedsman.
Daryl Baines
Feb 4, 2011 08:57 PM
skidip1
9
Aug 5, 2009 08:06 AM
debbie210363
Jan 24, 2007 07:48 PM
jmazza
Dec 8, 2006 07:18 PM
jmazza
Sep 15, 2006 07:57 PM
