intermittent bad starting
Old Nov 4, 2014 | 03:04 PM
  #31
rodger's Avatar
Hi fragmented
The relief valve is an innocent looking thing....
Take the plastic lid off the engine top,follow the common rail (where all the pipework to the injectors originates from) its the cast aluminium "tube" across the top of the engine. On the n/s (passenger side on UK vehicle) its located at the end of this "tube" all very accessible. Theres a small diameter flexible that takes any fuel back to the tank (I guess).
But!....this may not be your problem....someone added tomy thread and their problem was the pressure sensor.
Cost of valve was something over £100. This is a Bosch part and common to lots of other vehicles. I couldn't find it cheaper anywhere else so I got the diesel specialist I found to supply and fit. They billed me about £40 (I cant really remember) to fit . It was very reasonable.
This specialist is based in Maidstone, Kent and I would recommend them, they know what they are talking about. It was obviously a common fault to them, they had the part in stock.
Hope this helps..hope you fix it, mined bugged me for about 2 years! Still love the vehicle though!
Old Nov 4, 2014 | 03:55 PM
  #32
If it's a Bosch part go to a Bosch agent and he'll order it for you. Example Renault Scenic DCI one was about £150 from Renault, Bosch agent £75. Quite a few years ago.
Old Nov 11, 2014 | 03:45 AM
  #33
fragmented's Avatar
Been too busy to look at any of the suggestions made, I'm two weeks into the three week contract - 2300mls so far.
Anyway since Friday I've been able to start it without a spray.
I got angry with it and stamped the throttle peddle up and down while it was turning over and it starred, and it's started doing this ever since.
Does this point ot anything?
Thanks guys.
John
Old Nov 11, 2014 | 05:20 AM
  #34
Leedsman's Avatar
Fragmented -- what you just put suggests something wrong with fuel metering control by the micro. Curiously, since I started to run mine without the IOD fuse mod. as an experiment to save the parasitic battery load, the same change in starting has happened to me as with you. When cold, it starts the same as ever, no foot on accelerator. But when hot, the accelerator needs a good prod to start it. Mine has no trouble with cutting out etc., it starts always, runs the same as with the IOD fuse in position.
Leedsman.
Old Dec 3, 2014 | 08:55 AM
  #35
fragmented's Avatar
Time for an update.
Taking the suggestion from Rodger I invested in the leak off valve and since fitting it about 10 days ago it's started evey time so I'm hoping, after all this time it's sorted and this saga may be of help to others with similar issues.
Thanks to everyone who offered help and especially Rodger for coming up with what looks like the solution.
I'm going to start another thread with another couple of small issues [oh no] so if you have the time have a look.
John
jwbohrer
Oct 10, 2014 04:39 PM
Leedsman
Sep 20, 2014 05:45 AM
jtminnc
Oct 31, 2010 07:08 PM
dcraig10004
Aug 23, 2010 08:47 PM
1baddturbo
Jul 1, 2008 10:03 PM
