Jammed door lock
I have a 2007 T & C. The driver's side sliding door lock is totally jammed. I can not manually unlock it or open with key fob. I did replace the actuator a few months prior to the jamming and it was working great! Is this another actuator problem? a gas cap issue? a fuse? I really have not wanted to rip that door apart again as it is stuck closed and so much more difficult to work with in that position. Thoughts anyone? Really need some guidance!
Do you hear the actuator working when you use the fob or console buttons? My 04's had an auto lock that you had to be fully in park to allow door buttons to work the power doors. I s yours set up like that also?
I can hear a click when I hit the fob or console button. Nothing happens. My issue is I can't even unlock the door manually by pulling up on the knob. The door is unusable!
Sorry to say, but sounds like the rod from actuator to the lock has popped of and you are going to have to do a repeat of what you posted of having to do before AGAIN.
Thanks R59ebel. I was trying at all costs not to do that again. Really appreciate your insight!
