Jammed door lock
Old Sep 21, 2017 | 12:38 PM
trexxie's Avatar
Default Jammed door lock
I have a 2007 T & C. The driver's side sliding door lock is totally jammed. I can not manually unlock it or open with key fob. I did replace the actuator a few months prior to the jamming and it was working great! Is this another actuator problem? a gas cap issue? a fuse? I really have not wanted to rip that door apart again as it is stuck closed and so much more difficult to work with in that position. Thoughts anyone? Really need some guidance!
Old Sep 21, 2017 | 05:18 PM
REBEL59's Avatar
Do you hear the actuator working when you use the fob or console buttons? My 04's had an auto lock that you had to be fully in park to allow door buttons to work the power doors. I s yours set up like that also?
Old Sep 21, 2017 | 09:52 PM
trexxie's Avatar
I can hear a click when I hit the fob or console button. Nothing happens. My issue is I can't even unlock the door manually by pulling up on the ****. The door is unusable!
Old Sep 22, 2017 | 12:50 AM
REBEL59's Avatar
Sorry to say, but sounds like the rod from actuator to the lock has popped of and you are going to have to do a repeat of what you posted of having to do before AGAIN.
Old Sep 22, 2017 | 05:52 AM
trexxie's Avatar
Thanks R59ebel. I was trying at all costs not to do that again. Really appreciate your insight!
dimples1863
Feb 24, 2014 02:04 PM
dakrt360a
Oct 4, 2013 11:32 AM
Cglaspie
Sep 28, 2012 04:24 AM
pete3000
Nov 7, 2009 10:23 PM
randini
Sep 7, 2009 06:22 PM
