Lock unlock does not respond in right side door.
Old Aug 26, 2016 | 02:34 PM
Carlos Antillon's Avatar
Exclamation Lock unlock does not respond in right side door.
I have a question, the right-side door suddenly no longer worked on , and check the harness and looks good electric button , any ideas? Yesterday was working normally and today I found this issue, I need your advise to know were can I start to troubleshoot this fail. Thanks in advance!
Old Sep 2, 2016 | 07:19 AM
andyb2000's Avatar
Hi there,
So, when using the remote, or internal buttons for central locking, the door lock won't lock or unlock? If you pull the button up/down does it move freely?
My suspect would be the solenoid/actuator inside the door that moves the lock in and out of position. These give up after years and years of use (well, they become weaker to the point they can't move the mechanical lock). Best option would be to take the door trim off, locate the door lock actuator (It'll look like the picture below)
And remove it from the door mechanics. Then try again lock/unlock and see if it tries to move/moves slowly, makes a noise, etc. That would suggest it's faulty and need replacing.
Attached Thumbnails Lock unlock does not respond in right side door.-door_35.jpg
Old Sep 2, 2016 | 02:19 PM
Yes further to AndyB's words. Was just reading a repair on a Jaguar S-Types sticky door lock problem and this one showed up. How do we find the guilty actuator. Right, whenever the car was locked it would immediately unlock itself. This would also occur when the car was on the move as the Jaguars anti-hijack mechanism would lock then unlock. A door lock solenoid was thought to be sticking so which one was it. Manually locking the vehicle with key in drivers side made no difference so it wasn't that one. This suggested that the passenger lock was the culprit. (Has this car only got 2 doors what about the back doors). Anyway sitting inside, if the passenger lock was manually operated the car would remain locked. So new lock mechanism solenoid required for this door.
Not until you read it, it seems logical.
Old Sep 11, 2016 | 11:18 AM
Yes, he rights! I changed this part, and works, now I will review the old one, open, and try to lubricate, to see if works later.
Old Sep 12, 2016 | 03:55 AM
andyb2000's Avatar
Thumbs up
That's great news Carlos, thanks for posting back so others will know to look in the same place for this fault.
Old Sep 17, 2016 | 10:42 AM
s.m.'s Avatar
I had the same error on the same side. I changed the actuator yesterday and all works well now. I bought the actuator in China (20$ with shipping)
Old Jan 5, 2022 | 01:05 PM
Paulsmyth01's Avatar
Hi is it difficult to take the trim off without opening the door? My passenger front door is the same no response from inside abs outside and the lock is not always popping up when opened with the key.
jcar2
Aug 4, 2018 06:42 PM
Paulauryn
Sep 29, 2013 02:27 PM
ripper_666
Mar 6, 2012 09:17 PM
n0impulses
Mar 1, 2012 12:15 PM
bchickness
Oct 14, 2009 08:24 PM
