Looking for help in diagnosing a braking problem
Old Aug 16, 2016 | 11:23 AM
05sebringconv's Avatar
Are you absolutely sure you followed the correct procedure for bleeding the brakes for your particular model equipped with an ABS system ?
...sure sounds like you have air in the system or possibly its time to replace your rubber flex hoses. ( they are expanding and taking your fluid when pedal is pressed instead of sending it to calipers untill they finally reach a point where they hold the pressure and finally pass it along to the calipers resulting in a weak pedal that gets solid when pumped or at the bottom of travel )
First I would verify you have followed the correct procedure for ABS bleeding your particular model...
Calab
Mar 13, 2013 03:57 AM
MiniVanDad
Dec 14, 2012 07:47 PM
DIY Fizzle
Dec 13, 2011 07:26 AM
williajt
Aug 25, 2009 09:41 PM
quattj
May 8, 2007 05:40 AM
