-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   low compression-2002 TC (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/low-compression-2002-tc-17925/)
nelpasa Jul 16, 2012 01:58 PM
What should I do to correct low compression? Replace rings?. replace head gasket? Anything else?
CHRYSLER TECH Jul 16, 2012 02:10 PM
check the valves for holding pressure
nelpasa Jul 19, 2012 03:55 PM
I added oil to the cylinders and the compression did NOT change, DOES that indicate BAD VALVES?
CHRYSLER TECH Jul 19, 2012 04:29 PM
possible
nelpasa Jul 20, 2012 11:00 AM
any suggestion based on data provided?
CHRYSLER TECH Jul 20, 2012 06:01 PM
u already know the prob fix it
nelpasa Jul 21, 2012 12:11 PM
Would you say is the valves, not the piston rings? If I do not have to buy rings that will be a big saving for me. If I had money to spare I would have gone to the dealer's service department.
CHRYSLER TECH Jul 21, 2012 05:12 PM
if the rings were bad the trans fluid would have brought up the compression U said it did not.
nelpasa Jul 22, 2012 12:20 PM
thanks for the advise. just trying to do the correct thing at the lowest cost....
nelpasa Aug 10, 2012 12:47 PM
I grinded the valves with coarse grout and rechecked the compression. the compression went up to140 from 70, except on #1 and #3, which stayed low(110). Next I resurfaced the heads, regrinded the valves again and replaced the head-gaskets, now I am getting lower pressures than before resurfacing. Rechecked the compression with oil in cylinders but did not improve noticeable:confused: Could it be that I did not use fine grout?
PLEASE HELP
